- 11 Mar 2008
- Earth:\UK\Chelmsford
Have had weeks of intermittent or non-existent connections and tried every thing I could think of to resolve the intermittent wireless connectivity leading to long loading times for pages ending in 'Connection timed out'
I tried:
-Latest FW for router (F5D8230 Belkin Pre N)
-Different channels (1, 6, 11)
-QoS on/off
-Re-seating PCI adapter
-reinstalling NIC drivers
....before I realised I had no problems connecting under XP on lappy!
This made me realise that the router and signal was not an issue, but a Vista issue.
Some hours of googling later i stumbled across this and this.
It transpires that WPA is incompatible with Vista at this stage. M$ do have a Hotfix somewhere, but from memory that was to be incorporated into SP1, but doesn't appear to have worked for me.
SOLUTION: I am having to revert to the rather pap WEP connection to resolve the issue. Apart from the poo security I do now have a rock solid connection! Ironically WPA2 does work on XP lappy and Vista but is not supported by my desktop PCI adapter
This strikes me as a major issue and I am sure others must be suffering the same issue and hopefully this may help those in a similar situation avoid many weeks of wireless woes like me
I tried:
-QoS on/off
