I've got no idea how well this works
http://www.msfn.org/board/Vista-Update-Integrator-10Beta3-t114365.html
Thought some of you might like to try
Personally, i'm just using the MS SP1 iso's
-also, new vLite is out http://www.vlite.net/changelog.html (don't use it on a non sp1 source if you plan installing sp1, it will fail) -works fine on an sp1 source though
, I'll be off the other ways then!
