Vista Start Up Query's
5 Oct 2005
UK - Paignton
These questions will sound silly and picky but its always bothered me so here goes.
Vista boots up nice and fast for me but theres 2 annoying things.
Sometimes the internet won't work from the word go which means the weather gadget/internet dependant gadgets won't show up properly unless I restart them and Nod32 takes a minute fo fully load in which is a tad worrying.
After being idle on the desktop for a minute or just over at the very worst vista will then spring back into life, sort out the wirless connection so thats running and Nod32 will fully load in.
Before it loads them in I can use the pc just fine for anything so its almost like a service is causing this.
I'm using a wireless linksys usb adapter with just the drivers, not thier own software.
Anyone else using a wirless usb adapater have this happen randomly or had it and stopped it from happening?
Cheers.
Have you installed the latest version of NOD32 (v2.70.37)? I found that it loads a bit quicker.
