(Vista) Strange startup error
11 Aug 2006
Essex
Hey, I'm running windows vista ultimate (64x) and i get a strange error every time i boot up, it says windows calendar has stopped working and gives me the usual "close" or "check for solution" (which doesn't help)
any idea how i can fix this?
heres the report.
Windows Vista said:
Problem signature:
Problem Event Name: APPCRASH
Application Name: WinCal.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549bbff
Fault Module Name: WinCal.exe
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549bbff
Exception Code: c0000005
Exception Offset: 000000000006d2ba
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 2057
Additional Information 1: 3a12
Additional Information 2: ff4fe2301a6cf2caaa3e293e8e16c2dd
Additional Information 3: 7436
Additional Information 4: e53b0a27af89e64a6d46087ed06b67ba
I have seen this a few times and it is generally caused by a corrupt calendar.
When a user logs on vista runs a scheduled task which will pop up any calendar reminders.
There are 2 options here.
1) Delete and recreate the calendar
2) Disable the scheduled start-up task (This disables reminders!)
To disable the scheduled task
Control panel / Administrative tools / Task Scheduler
In the left hand Payne Expand "Task Scheduler Library" / "Microsoft" / "Windows".
Click "Windows Calendar"
In the right hand, top Payne right click "Reminders - " and select disable.
SuperPlay
