Vista System Cleaners
5 Mar 2006
Scotland
Im looking for a combination of Reg cleaners/system cleaners fro Vista. Before on XP I used a combination of Registry Mechanic, CCleaner/Easy Cleaner and Webroot Window Washer. Does anyone use window washer with Vista? or Reg Mechanic?
I used the Reg Cleaner on EasyCleaner at the weekend.....and it ran constatly for about half an hour...and picked up hundreds!!!! of files to wipe. Wasnt to sure TBH!
CCleaner is all you really need for registry cleaning and removing unwanted data from temp folders etc.
I use it for this on a Vista 64bit install..upon which it works very well. :)
just be careful with CCleaner in vista 64bit.
in winXP CCleaner never deleted anything i didnt want it too, but in vista 64bit it has deleted the odd thing i didnt tell it too(like some of my desktop icons
ShakenNstirred said:
just be careful with CCleaner in vista 64bit.....it has deleted the odd thing i didnt tell it too(like some of my desktop icons
Never had any problems personally in Vista 64bit....and if you make a backup (as you should do), you can always replace what has been deleted. :)
i know
but it shouldnt be deleting them in the first place, it never did in winXP
