- 17 Mar 2008
I'm torn between purchasing 32 bit or 64 bit Vista Ultimate with a system on PC builder on OC. I want to run games (obviously), Solid Edge V.19 and Adobe Design Premium CS3; as well as use IE7 and Office for normal stuff. As the system comes with either of the 2 OEM versions; I won't have the retail version (that comes with both 32 and 64 bit).
I've heard 64 bit is good for demanding programs (as you can utilize the extra RAM); but there's problems with drivers, some software and using it for basic functions (like surfing and word processing etc.). Also do games out recently support 64-bit?
I'm purchasing a PC with 4GB, and obviously 32-bit does not use all of it. But am torn between the two due to in-compatabilities in 64-bit and non-utilisation of RAM in 32-bit.
I was wondering how valid or how far from the truth the above points are, and if anyone can give me any help in selection? Also, has SP1 helped with 64-bit in anyway? (I know SP1 now shows there is more than 3.x GB of RAM, although doesn't use it) Any information from anyone that uses CS3 or Solid Edge v.19, would also be a great help?
