I have a cheapy Sound Blaster Audigy SE which OcUK kindly supplied me with my build, but unfortunately, there is no X64 driver (and as its a low spec card, Creative are suggesting on their forum that a 64-bit driver will probably not be forthcoming).
Fortunately, I've managed to use the XP 64-Bit driver and sign into Vista by disabling the need to use digitally signed drivers, but this isn't ideal.
I would therefore be grateful if someone could recommend me a suitable Vista 64-Bit compatible sound card. It doesn't need to be anything special, i only use it with 2.1 speakers to listen to some music and watch movies.
Thanks
Thanks
