Interesting indeed as that should not be possibleacs1 said:Interesting I have the upgrade version of vista and just managed to dual boot both that and xp. When I installed vista via xp it asked me to upgrade or clean install on a different partition, which I did, and installed it on my d drive, with xp on my c and it works perfectly.
Dutch Guy said:Interesting indeed as that should not be possible![]()
Perhaps in your situation it is possible as you already have XP installed?
Have you activated Vista yet without problems?
Although you may have done it, surely it is against the license terms.acs1 said:Interesting I have the upgrade version of vista and just managed to dual boot both that and xp. When I installed vista via xp it asked me to upgrade or clean install on a different partition, which I did, and installed it on my d drive, with xp on my c and it works perfectly.
dirtydog said:Although you may have done it, surely it is against the license terms.
Dutch Guy said:I don't think this is against the rules as you still need a valid XP install for it to work, I doubt Vista will install if you have an illegal XP install.
I think I see what you mean, so legally you can only have 1 installed OS, either XP or Vista, not XP and Vista?burnsy2023 said:It is most definetly against the Licencing terms. You are licenced per copy, per device, meaning only one installation of XP is allowed per machine. You may think that as you have XP and Vista on the same machine you are fine as you only have on installation of XP, but that's not quite right. You need a fully licenced qualifying product for the upgrade and by already having an existing XP installation, you void the right to use Vista.
Burnsy
Burnsy
MrLOL said:either you've got your facts wrong or its another case of MS saying one thing, and doing another.
Dutch Guy said:I think I see what you mean, so legally you can only have 1 installed OS, either XP or Vista, not XP and Vista?
You may install, use, access, display and run one copy of the SOFTWARE on the COMPUTER.
