Vista virgin - need some help please
31 Aug 2007
Guys, 1st time I have installed Vista (Home Premium 32bit) even though I have had it sitting on my desk for months!!
Anyway, it's installed and in the process of being updated with SP1 and all the other patches.
I plan on setting the Start Menu etc as I had it in XP (which was the Classic Start Menu :p), just because I don't like the whole new arrangement. I have never got comfortable with it at all, and just prefer the familiar setup.
What I want to know is how do I get rid of all these damn annoying 'Do you want to allow this'...etc etc rubbish?
Is there a useful guide out there that's worth taking a look at?
Thanks a lot.
Since it is your first time you have installed Windows Vista, you will get a fair amount of prompts to begin with since you are going through the initial phase of setting up the operating system. However, after this initial stage, the prompts should quieten down and you should rarely come across any. Then you can set yourself up to run from a standard user account. I would highly recommend keeping User Account Control enabled though
However, if you are still experiencing lots of prompts and getting fed up with them, then you can tweak it so all tasks that request elevation will be automatically elevated and you can do this via the registry or TweakUAC - Silent Mode as bledd has pointed out. This obviously isn't as secure as leaving it enabled but it's better than turning it off completely.
Thanks again. I have one thing really bugging me already. On boot up, uGuru loads and I always get a message saying 'a program needs your permission to continue' or something along those lines.
Is there any way to disable that warning, or make it remember my selection so it stops asking at every boot?
Rather than disable the new start menu, try using it for a week or so - I'd never go back now.
The really nice feature is that if you hit the windows key and then start typing the name of the program you want it brings it up in the search pane - typically you'll only need to enter 3 letters (for instance if I want to load up the Remote Desktop Client I hit [windows][r][e][m][enter]). Much quicker than clicking and scrolling through a list of programs.
Thanks guys. Maybe i'll put up with it for a little while then. It is just so unfamiliar. Kind of why I disabled it in XP, but I guess you have to move forward at some point!
Yes the Quiet mode in Vista is still crap and it's been reported so when the UAC comparisons have been done between Vista and Win7 - Which is why MS listened and added more control built into 7 for UAC control and notifications for elevation requests.
Switch the son of a bitch off then. As long as you aren't the sort to randomly click on popups on pr0n sites and such you should be OK. I've had it switched off since Vista day one [about a year ago] with no ill effects.
