Vista : Where's search!
18 Oct 2002
Cambridge, UK
Hi,
I don't seem to have seach on my "start" menu, how do I add it?
Thanks
Ah I see, probably some sort of hack or reg tweak, what’s the need to have it on the start menu? Isn’t it easier just to write in the search box?
Iirc SP1 removes search from the start menu doesn't it? I remember reading something about that.
rightclick toolbar and select "properties"
click "start menu" tab the select "customise" next to your chosen start menu style.
You can activate search in the options that come up.
hth
wish classic search was in vista too though, it's tons better at times
Definitely, the Win2k style UI for advanced search seems a lot easier to use I find - tell it where you want to look, and then search on a filename and/or text string. Additional filters as appopriate but usually not required due to it's speed.
yay for NTFS indexing!
