Vista & Wireless Router
22 Jan 2005
West London
I'm having trouble connecting my Sony Vaio Vista to my wireless router.
I can connect via ethernet with no problems, it works as soon as I plug the cable in. However I can't get it to connect wirelessly. I've already tried following both methods here but still no luck. I get an error saying my passphrase is entered incorrectly however I know for a fact it is correct.
Im using wpa personal, I have the correct network id, and the correct passphase. I've also tried setting the router to allow new registrations and then connecting, but to no avail.
Is there a solution, or is this a vista problem?
Have you tried changing the ecryption method, ie. try using TKIP instead. Or change to WPA2. Also check for new drivers for your wireless connector.
