Hi,
I just recently bought the "Ultima 8800GTX" AMD Athlon 64 X2 6000 3.00GHz Dual Core SILENT DDR2 System (http://www.overclockers.co.uk/showproduct.php?prodid=FS-043-OK&groupid=43&catid=1055&subcat=).
I installed all the drivers that came with the system, but there are two things that dont seem quite right. First of all, the processor is showing as an AMD 5600+ 2.81 GHz, when it should be 6000 3.00 Ghz.
Second, the graphics card says it is a 8800 GTS 512, instead of an 8800 GTX 768.
Now i'm wondering how I can correct this, how can I force it to install the correct drivers instead of the wrong ones when the drivers are all "one size fits all" intended for lots of different models of graphics cards and processors.
It is quite irritating to have it think I have a graphics card which is £100 cheaper than what I am meant to have.
My other worry is that the drivers are actually correct and that the wrong hardware was installed by mistake.
Any help on working out how to rectify the issue would be appreciated
