Vista64 not recognising second raid drive on Maximus Formula
18 Nov 2007
Just setting up my new Maximus Formula board - connected everything up, went into the raid utility, set up both my raid drives (2xSeagates for main system files etc, 2x WD Raptors for games - both Raid0), no problems. Inserted the Vista DVD and started to install. But, it wouldn't recognise any of the drives. I read somewhere that Vista can struggle if there are two sets of drives installed, so I removed the two WD and it worked - installed onto the two Seagates, no problem.
I've now reconnected the WDs and Vista will not recognise them. I can see them in the BIOS utility and I can even see them in device manager! :mad: Tried installing the Asus drivers in Vista, still no joy. Is there somethign I'm missing here??! :confused:
Any help on this would be massively appriciated!
No panic - sorted it this way:
Control Panel, look for Admin Tools, then look for Comp Management, then choose Disc Management. Create Volume, rename etc
Bl00dy Vista :mad: :D
