Vista64bit RAM usage is lower than 32bit ?
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Now I'm all up and running on 64bit and it's amazing, slicker than 32bit yet I find it is using 20% less RAM than Vista32 with the same background apps running - is this a tip of the hat to a 64bit OS ?
Right now it's using 33% of 4GB whilst Vista32 would be using between 50% and 55% in normal Windows usage with Firefox running and other systray apps.
Happy either way but would like to know if anyone else experienced this ?
How long have you had 64 bit running? It may well be that it's not started pre-loading apps via readyboost yet.
Edit: I mean superfectch
Only since this morning ¬_¬
You may be right, Superfetch has not had enough time to train yet so perhaps this is what it is !
Are you calculating that "%" by including the cache?
The memory used by superfetch is not included in the "physical memory usage graph". It is shown seperately under "Cached"...
My usage would be almost 99% if I included the cache.
Don't forget that Vista32 can't use all 4GB.
For example, if you have a graphics card with 512MB...
50% of 3.3GB = 1.65GB
33% of 4.0GB = 1.32GB
So, still less, but not as much less as first appearances may suggest. A graphics card with more RAM will further narrow the gap (and vice versa).
