Visual acuity, help!
6 Feb 2006
Troon
I am applying for the police soon and I was wondering if anyone had any idea how to work out your visual acuity. I got the following information from the Strathclyde police website
Visual Acuity Form
If you wear glasses or contact lenses, you are required to have a Visual Acuity Form completed by your optician. The completed form must be returned with your application.
The eyesight requirements for the Force have recently changed:
Uncorrected visual acuity: 6/36 (or better) in each eye.
Corrected visual acuity: 6/12 (or better) in each eye.
Binocular vision (+/- correction) : 6/6 (or better).
Near vision (+/- correction) : N9 (or better).
I wear contacts most of the time when I’m out or driving and the pwr on the left is -1.50 and the right is -1.25 but I don’t understand how these numbers relate to the 6/36, anyone got any ideas?
I’m considering saving up for corrective surgery on them if it proves to be an issue which i think it might.
I had corrective surgery about 8 years ago and it is worth it.
Most forces accept people who have had it done but see if your unaided vision meets the criteria first.
I would pop into your local optician to find out more, he will soon put you on the right track. I am not sure if the vision requirements differ from force to force or are part of a Home Office / Scottish Office general requirement.
But surely Mr Von Smallhausen sir...that means you must be......but......surely not! :eek:
im planning on applying for the same force soon!!!
you can print off the V.A form from the Strath Police web site, then get an appointment with boots/optician and they will do the rest for ya.
I had corrective surgery about 8 years ago and it is worth it.QUOTE]
which version of corrective surgory did you have? Lazer or grinding? if you dont mind me asking.
I had it when it was PRK. The technology had changes since then.
It was laser and the protectice layer over the cornea was removed by laser before the treatment. I was on steroid drops for about 2-3 months afterwards which doesn't happen now. This stopped scar tissue forming as the lasers weren't as accurate as they are now.
I see. I understand that the Mility is considering/are grinding the Lense to keep pilots for longer in the air, as they feel that laser treatments weaken the eyes and they were concerned with the effects of combat. Tis why i was asking.
Best bet is to go to the opticians but i can tell you what some of the things mean after much research last week for similar circumstances.
The 6/36 is to do with how well you can see at distance (same as 20/20 but metric). Normal vision is 6/6, or 20/20 (meaning you can see a size 6 print at 6 metres, this is usually the second line from the bottom on the letter chart) perfect being 6/4 (meaning you can see size 4 print (smaller) at 6 metres), so the smaller the second number the better. :)
I found this link really helpful when i was looking, it a little long winded but it has all the information you'll need. :)
Im not sure how that corresponds to your contact prescription though as usually the optician works out a SPH and a CYL number fo both your eyes and you only seem to have one which i assume is the prescription for your contacts not one of the figures. :(
I hope this has sort of helped and hasnt confused you even more. :p
6/36 refers to the line on the eye chart that you can see and the distance at which you stand from it i.e. from standing 6 meters from the chart you can see the 2nd line without having your vision corrected. This basically means that a person with normal vision would be able to see the same line on the chart from 36 meters away. This is the standard my vision is with being corrected by -20.00 and -19.50 contact's thus making me severely visually impaired.
Your prescription sounds very small so I suspect you'd be fine with this. If you have normal vision when wearing your contacts then you would have 6/6. If your eyesight is not so good the next line above that would be 6/12. It usually says on your prescription.
