Visual Basic/C++ etc...
Permabanned
15 Oct 2006
Scotland
Okay so I've installed these programs, now the problem is that once installed, the next day when I turned on the PC, (I am the only user) and it came up the login screen, so I just clicked on my name wondering why it did that?
So I checked the user accounts and it has "SQL Debugger" as an user account. It is an restricted account and its password protected. Point is can I delete this or is it needed? its just annoying having to click to login everytime.
Cheers.
try deleting it
i've got SQL server 2005 on my system, and Visual Web Developer Express and dont have this account
cant think its needed
if it is, you can allways re-install the software.
Cheers.
are you using the 1.1 framework? update it :) there is a patch from Microsoft for the logon screen problem but I cant find it atm
edit: found it http://support.microsoft.com/kb/827072
