Caporegime
- 18 Sep 2009
- Dormanstown.
Hey.
I'm currently doing a HCI assignment which has us using VB, the teacher doesn't mind if the code's not original, he only cares about the presentation.
But given his bland explanation of presentation, it's very varied.
Anyways.
The program that we're to create is a reactions test.
Currently, my programs consists of these forms ;
My splash page
My main page
My options page
My help page
The reactions test page (You'll realise while it's blank)
My results page
What the program currently does ;
When you start the program, it'll load up frmSplash (As it should), that will take you to frmMain (As it should). The user can then go onto frmOptions and select the background and text colour (Becomes apparent later), they can then go back to frmMain, and then onto frmHelp, and then back to frmMain.
Anyways, then when the game is started on frmReactionsTest, the lblTest will load up the colour that you've chosen in frmOptions.
This is where it gets tricky, and I'm stuck. I must make the letter A appear around different locations of lblTest 20 times at 3 second intervals after the space bar has been pressed. Each time the letter A appears there should be a counter, which is then stopped after the space bar is pressed. And it'll continue on the next letter A appearing.
After 20 times it should average your time it took per click, and those results should be displayed in frmResults.
I have NO idea how to do this, and neither does our coding (Not HCI) teacher, hell, selecting the colours our coding teacher used ridiculously complicated coding with highlighting etc, when mine does the same thing with about 10 times less coding.
So, any coding guru's can help
I'll send you my .rar which has my Visualbasic project, along with all my images.
Anyways.
My splash page
My main page
My options page
My help page
My results page
