Ok well i am in the process of learning Visual Basic but have bumped into a small hurdle, primarily around this folderbrowserdialog
I want to be able to open the folder which ive selected in the browser dialogue when the button OK is pressed. Here is my current code.
I tried using Shell on the defined Dims and Consts As the general idea of the script was to just test around file navigation on my system for instance the path_name was a public const i had defined which had a route of "C:\Windows" now i know if i were to shell like shell("explorer C:\Windows") it would open that directory, but i want to do it with a public const that i had defined or even a dim value as string for instance.
So how would i go about the first step of opening the file that has been selected?
Thanks.
Code:
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles materials.Click
Dim Folder_Browse_Materials As New FolderBrowserDialog
With Folder_Browse_Materials
.RootFolder = Environment.SpecialFolder.Desktop
.SelectedPath = path_name
.Description = "Select Source Dir"
If .ShowDialog = Windows.Forms.DialogResult.OK Then
' THIS IS WHERE THE OPEN THE FOLDER SCRIPT SHOULD GO RIGHT? '
End If
End With
End Sub
Thanks.
