do you know how he's encrypted the file? if there are only 254 possible choices for the key and you know the algorithm just run the decryption with sequential keys untill you decrypt it, if you don't knwo how he's encrypted it you're up a creek without a paddle.
If you're up that creek you have two options,
A: get your friend to tell you
B: Go to university and do a computer forensics course
I'd sugest option A
Paul
