I've created a small program that loads an image from my D drive.
If those image files are moved, or if their containing folders are renamed, then the program cannot access those images (and crashes).
How would i go about creating the exe so that the image files are included in the program?
So that if i were to send someone the program, i could just send the Prog.exe and it would work fine, without having to also places image files in a specific folder on their drive.
I've tried googling for it, but i don't know enough to use the right search terms, etc
(I'm using VB 2008 Express Edition)
