Visual Studio 2005 & Windows Mobile 2005 Problem
28 Nov 2005
Scotland
Have Visual Studio 2005 Pro.
I also have a Windows Mobile 5 phone.
Now on Visual studio you can create applications for devices up to windows mobile 2003. When you open and choose new project and your language then smart device it just lists 2003 smartphone and pocket PC.
If you wan to create apps for mobile 5 you have to download the WM Developer Resource Kit and install it, then install Windows Mobile 5.0 Pocket PC SDK and Windows Mobile 5.0 Smartphone SDK.
Now when you do so by rights you should be able to create apps for smartphone and pocket PC 2005, so when you open visual studio and choose new project and your language then smart device it should list all 2003 and 2005, however mines dosnt! After i install them all i still only get smartphone and pocket PC 2003, i should also now get windows CE 5.0 this i do get but not the rest.
Can anyone suggest or help me here?
Also when i try to create a visual basic smartphone app i get the following error:
Project 'Project1' could not be opened because mthe Micrsoft Visual Basic 2005 compiler could not be created. Unable to find required file 'mscorlib.dll'.
Also when i create a normal VB app it jsut dont work, loads of errors etc come up.
Can anyone help at all?
Thanks
Gary
