Visual Studio 2026
26 Jan 2024
North Yorkshire
Anyone had a proper crack at it yet?
I've been using it for all my .Net work and the only real benefit I'm seeing it the "live" view of variable values while debugging, which is really helpful tbf.
None of my projects are big enough to comment on build times or anything like that and I don't use any of the AI stuff.
I came across my first real issue this morning though. I added a parameter to a service method and its interface, but the references to the method in my controller weren't "seeing" the new parameter. F12 took me to an old decompiled version. No amount of cleaning & rebuilding fixed the problem.
I opened the solution in VS2022 and hey presto it works as expected.
What does this mean? How does the new "live" view differ from seeing the value of variables while you're stepping through in previous versions?
Basically (almost) any variable that's on screen and part of your current "flow"(?) of code will have its current value displayed next to it so you don't have to pin variables or hover.
Hmm. It's not really obvious to me why that's better than having the variables in the watch window, maybe it's something I need to see in person to appreciate.
I've been trying to move away from using Visual Studio mostly, I find it's too heavyweight for the work I do and the design increasingly feels old and cluttered.
Agreed. I was vainly hoping for something new & shiny for 2026 but it seems to be more of an "under the hood" upgrade. I wouldn't use it if I didn't have to.
Yeah I've been using it, observations:
- no blue theme, had to install a theme to get it back
- performs miles better
- my test coverage extension broke, but now it has test coverage built in, it's an adjustment though because it works differently
Does it have copilot built in?
It does, and it's still just as useless as it was in VS22.
This is all I really care about. There's a whole world of junk in VS that is surplus to requirements most of the time. It'd be nice if we could have a 'base' install and only add what we actually need for our own workflows.
I'm a bit late her. I use vs2026 for work. We have large solutions with quite a few projects and they load slower than vs2022. Copilot is built in, but it is in vs2022. You can use it a limited number of times a month for free.
Been using it for my Unreal work, and pleasantly surprised how it’s just got out of my way and not annoyed me, without too much faffing about. No random stalls or issues with performance on a big project.
Have you tried Rider? If so do you find VS 2026 better?
Yeah I’ve worked with Rider a bit, professionally for a year or two.
I think a few years ago Visual Studio was still awful with big codebases, had to spend ages tweaking things to get rid of the random freezing and general sluggishness. Rider was kinda snappy and fast at first, but now I find it’s just too noisy and I have to turn lots of stuff off to get back to a simpler UI that uses the space better.
For debugging I’ve always stuck with visual studio, for getting into the weeks with gnarly C++ issues the various debugging tools in VS are still the best option.
I think I could work perfectly fine in both VS and Rider tbh, and Rider has the advantage of a decent Claude Code integration which Visual Studio is lacking right now….but for game dev I’m sticking with VS.
I've been using 2026 for a while now (C++ and C# projects) and prefer it over previous versions. No major issues to report, apart from the odd freeze when trying to launch a Debug build, but that is rare. It's hard to say whether or not it performs better than previous versions; some things feel quicker, some feel the same. I don't feel there have been any backward steps. I quite like the subtle aesthetic changes, too. :cry:
