Visual Studio code block select
No, dont think you can unfortunately (not that i've come across in VS anyway).
VS2010 has a block select option when you press alt and drag or arrow which can be handy but I cannot think of a way to auto-select a given block.
Might just be me, but when i'm playing with the HTML code in VS 2010, when I click an element I can then click the box it relates to at the bottom of the screen, this then highlights all the text within that element.
It's definitely worth it. It makes refactoring pretty much effortless and the code hints it gives you (convert to LINQ, fix capitalisation) are great.
I had it but the Free Trial expired, it's tempting to get a license for it though.
Same here, wish it was just a wee bit cheaper. It'd be ok if I just needed the C# OR VB versions as £116 isn't too bad but I use both languages regularly so would need the full edition to get both.
Also see its now has XAML editing tools that would come in real handy...
Just using a trial of resharper, I feel I don't fully know or appreciate everything it can do, any one got any advice for what it's capable of??
