Visual Styles
Thanks, but now another problem has arised.
When I try to install the themes it says the themes service isn't running, so I go into RUN > Services.msc and try to find themes service, nothing. Which service does themes actually use? I think i might have removed it with my nLite slimmed down install. is there anyway to put it back onto my system?
there should be a server there listed as 'Themes'. I had a issue with that uxtheme patch before, could have been this same one..not 100% sure how i fixed it but you may want to undo the patch and try again.
Nope, the app just patches it, no option to undo it. I have a system restore for before i done it, but since then ive gotten 4+ GB of apps, i dont really want to resort to that.
