Vivaldi 1.6 Released!
22 Sep 2006
Changelog
[New feature][Tabs] Detect numbers enclosed in brackets (parentheses) in page title to use as tab notifications (VB-23635)
[New Feature][Tabs] Ctrl/⌘ double click tab should select tabs of same host (VB-23096)
[New Feature][Tabs] Title renaming for tab stack: enable via "Settings → Tabs → Tab Features" (VB-23491)
[New feature][URL field] Ctrl or ⌘ click on the address to cut off the rest of the URL (VB-23671)
[Windows][HiDPI] HTML in update dialog not HIDPI friendly (VB-17735)
[Windows][HiDPI] Installer looks blurry on HiDPI displays (VB-23934)
[Windows] Maximized browser window overflows 1-2 pixels onto second monitor (VB-18258)
[Windows] Updater window out of focus (VB-22431)
[Windows] Auto update should not open immediately after user has checked for update manually (VB-23857)
[Bookmarks] Drag and Drop misbehaves on bookmark bar (VB-23606)
[Bookmarks] Show site name or URL in tooltip when hover an icon in bookmarks bar (VB-22887)
[Bookmarks] Reduce vertical space in Edit Mode for panel (VB-23108)
[Bookmarks][Speed Dial] Improve copy/cut/paste for bookmark tree, bookmark bar and Speed Dials (VB-23339)
[Bookmarks] Can not drop a URL after last item on the bookmark bar (VB-23401)
[Extensions] Click the same extension button doesn't close its menu (VB-17312)
[Extensions] Last pass search field not auto focused (VB-17739)
[IME] hover in address bar turns the text invisible (VB-23313)
[Notes] It should be possible to map copy marked text to new note as a keyboard shortcut (VB-4018)
[Reader mode] Button re-paints upon loading new tab/reload (VB-23040)
[Reader mode] Should not show on reddit.com (VB-23615)
[Reader mode] update needed because failures on a few sites (VB-23661)
[Search field] Dropdown not closing on new tab (VB-23738)
[Search field] Added setting for always opening result in new tab (VB-23648)
[Search field] Search bar typed history is filtered towards content in search bar (VB-23612)
[Search field] Delete typed history not working correctly (VB-23927)
[Search field] Remove the icon from typed history
[Search field] Alt+Enter no longer opens new tab (VB-23357)
[Speed Dial] Cannot show unlimited Speed Dials in one folder (VB-16864)
[Tabs] Blank page if the only tab of the window is dragged to the same tab bar (VB-23412)
[Tabs] Clicking on active tab doesn't always switch to the last used tab, after enabling "Click active tab to switch to previous tab" (VB-23212)
[Tabs] Stacked tabs dragged together even with stacking off (VB-23340)
[Tabs] Group the tab stack related context menu items
[Tabs] When both pinned and unpinned tabs selected only Unpin option in context menu, toggling states (VB-23080)
[Thumbnails] Pages loaded in background tab do not update thumbnail (VB-2991)
[URL field] Search in address field settings are out of sync (VB-23290)
[URL field][Search field] Focus styling is not the same as default UI focus (VB-23260)
[URL field] Copying the first character in the URL bar results in the entire contents being copied (VB-23246)
Improved startup procedure
No Referer Header with open new tab (VB-11034)
Mouse cursor not hidden when video is in fullscreen mode (VB-4297)
Fullscreen does not show hint on activation (VB-11689)
Missing Numeric pad shortcuts for single key shortcuts (VB-23495)
Backspace in text fields in web panels triggers going back (VB-23630)
Improve tree auto expand during drag and drop (VB-23387)
Incorrect Context Menu for Tab-stack Move To Submenu (VB-23395)
Simplify drag and drop around trashcan in trees (VB-23177)
Updated Chromium to 55.0.2883.92
https://vivaldi.net/en-US/teamblog/195-details-matter-vivaldi-1-6-is-ready
Fast stable Chromium based web browser :) .
