Vivaldi 2.3 Browser Released (With Auto Stacking).
22 Sep 2006
https://vivaldi.com/blog/
The stable release of Vivaldi 2.3 has arrived!
Changelog since 2.2 (1388.37)
Our first update of the year includes a new way to keep your tabs organised "Auto-Stacking" and adds an option to show Frequently Visited Sites in the Address Field drop-down results.
Get the full story by visiting the Vivaldi blog (vivaldi.com/blog)
  • [New] Option to automatically create a tab stack: ‘Settings → New Tab Position → As Tab Stack with Related Tab’ VB-15514
  • [New] Add an option to show frequently visited pages in the URL Drop-Down: “Settings → Address bar → Address Field Drop-Down Menu → Include Frequently Visited Pages” VB-3533
  • [New] Custom screenshot file name VB-31991
  • [New] Save webpage as MHTML is enabled VB-2101
  • [New] Spinner favicon when a tab is loading VB-46130
  • [New] Passwords should be viewable in Settings VB-14045
  • [New][Windows][Linux] Add confirmation dialog on exit VB-6951
  • [Linux] Middle-click on tab Trash pastes buffered text into History search field VB-46281
  • [Mac] Clicking a certain extension icons makes Vivaldi crash VB-44298
  • [Mac] Impossible to do live video on Facebook VB-45131
  • [Mac] Show the context menu on mouse down if mouse gestures are disabled VB-48159
  • [Mac] Swipe between pages with three fingers not working when using native window VB-44729
  • [Windows] All-users install does not use installed language/locale VB-47569
  • [Windows] Twitch.tv process crashes after a little while with HWA disabled VB-30760
  • [Developer Tools] Opening links from inspector opens them twice VB-11330
  • [Developer Tools] Saving an image doesn’t work VB-47836
  • [Extensions] Evernote extension will not accept keystrokes VB-42683
  • [Extensions] Official Chrome API chrome.extension.getViews popup doesn’t work VB-46910
  • [Gestures] Allow right-button and Alt-key mouse gestures to be independent VB-46727
  • [Page Interaction] Focus page upon pressing Homepage button VB-36693
  • [Page Interaction] Reader settings visible on all tiled pages VB-47161
  • [Panels] Web panels cannot be reloaded via the context menu VB-47118
  • [Panels] Download panel does not respect ordering on initialization VB-47985
  • [Quick Commands] Highlight search instead of note after paste VB-47641
  • [Search] ‘Always Search in New Tab’ affects Speed Dial VB-46484
  • [Settings] Add ability to search for search engines VB-35583
  • [Settings] Add option to keep last selected search engine VB-45455
  • [Settings] Delete only focused shortcut with Remove Shortcut button VB-46950
  • [Settings] Homepage input scheme resets to http VB-35520
  • [Speed Dial] Cannot add file:// URL to Speed Dial VB-19722
  • [Speed Dial] Paste does not work in search field VB-48416
  • [Tabs] Custom internal page favicons VB-26354
  • [Tabs] Tabs dragged out of stack to another rejoins first stack VB-45713
  • [UI] Aspect Ratio of Bookmark Thumbnails VB-44261
  • [UI] Key icon and address field icons not visible in Incognito mode and Dark themes VB-47256
  • [UI] No close window warning if browser is closed by other means VB-47549
  • [UI] Scrollbar gap on Windows and Linux VB-47350
  • [UI] Reader view button moves the address field dropdown button VB-47968
  • PageUp/PageDown and arrow up/down does not work after opening in new tab VB-48133
  • Re-ordering a tiled tab with internal PDF reader reloads example PDF VB-48266
  • Tab in background window closed with mouse gesture over visible tab in another window VB-47721
  • Unable to scroll PDF up/down with keyboard after clicking “Fit to page” VB-44083
  • Upgraded Chromium to 72.0.3626.82
