Vivaldi 3.4 Released! (now with configurable context menus)
22 Sep 2006
https://vivaldi.com/blog/three-chee...arrives/#pk_campaign=release-notes&pk_kwd=3.4
Changelog – Vivaldi Browser 3.3 to 3.4 on Desktop
New Features
  • Vivaldia game (VB-70893)
  • [Menus] Add support for custom links via an “Open link” command (VB-72316)
  • [Menus] Support for configurable context menus (VB-71660)
  • [Notes][Capture] Option to directly attach a screenshot to a note (VB-71725)
  • [Quick Commands][Keyboard][Gestures] Improved tiling commands: prioritizes 1) current tab selection, 2) current tab stack, 3) active + last visible tab (VB-71223)
  • [Speed Dial] Drag one item onto another to create a folder with both (VB-29880)
  • [Tabs] Periodic reloader with custom intervals (VB-7524)
  • [User Profiles] Allow for using a local image as avatar image (VB-71849)
Address Bar
  • Focus removes double slashes after URL scheme in extension URLs (VB-71625)
  • Need to double tap delete when editing a suggested URL (VB-72426)
  • Search fails when clicking “Go to address” (VB-71346)
  • Search parsing breaks with Google’s ‘site:’ search (VB-72423)
  • URL gets cleared when moving the tab between windows (VB-71907)
  • [Settings] “Include Browser History” option reverts to unchecked (VB-71350)
Bookmarks
  • Focus styling bugs in the bookmark bar (VB-71597)
  • “New Folder” in Bookmarks not selected on creation (VB-71397)
  • [Address bar][Themes] Add bookmark in address bar becomes “invisible” (VB-64131)
Break Mode
  • End break when closing browser (VB-71530)
  • Make it easier for user to exit: allow the user to click play to resume (VB-72861)
Popout Video
  • Allow PiP window to be larger than half the monitor size (VB-72508)
  • Now available for Dailymotion videos (VB-69364)
Tabs
  • Small tab internal page favicons disappear when hovered (VB-71602)
  • Tiling button sets incorrect default layout (VB-71508)
  • “Hibernate background tabs” hibernates visible tabs (VB-13680)
Themes
  • Accent Color from active page still not working reliably (VB-72133)
  • [Tabs] Use “highlight” color for selection (VB-57784)
Others
  • [Blocker] Format blocking exceptions and warn if invalid (VB-69511)
  • [Chromium] Upgraded to 86.0.4240.101
  • [Clock][Toolbars] Drop-down arrow starts over button instead of underneath (VB-71654)
  • [HiDPI] Find in Page match highlight duplicated with wrong offset (VB-72127)
  • [Linux][Media] Update proprietary codecs to 85.0.4183.121
  • [Menu] Update Help Menu (VB-71846)
  • [Notes][Themes] Notes Editor in Private Window has wrong text color (VB-71077)
  • [Permission notifications] Default Permission for “Popups” reverts from “Ask” to “Block” (VB-71357)
  • [Screen capture] Not possible to cancel capture with mouse or on touch screen (VB-44466)
  • [Settings] Remove defunct buttons in Startpage background settings (VB-70509)
  • [Spatial Navigation] Problems with scrolling and indicator init: handles cases when scrolling and no elements are available
  • [Speed Dial] “Paste & go” option in search opens two pages (VB-58834)
  • [Web Panels] Download links don’t work (VB-53443)
  • [Welcome page] Updates (VB-71601)
  • [Windows] Vivaldi taskbar icon targets vivaldi_proxy.exe (VB-72821)
  • [macOS] Will not maximize on double click (VB-71676)
I tried Vivaldi last week. Didn't like it. Cluttered UI.
I did try Brave though and that was good.
But lacking at least one feature which I have become used to in Firefox.
That is the 4 green ticks on this security check.
I do believe that no browser except for Firefox can get 4 green ticks currently.
Surprised you find it cluttered considering you can add/remove stuff and move things around, I don't like Firefox (I was a pre Quantum Firefox fan btw) ,my mum(in her late 70s) uses it on her laptop, but on some sites it refuses to scroll properly ie goes into a loop cycle where you can't get to bottom of the page, this is with no add on or extensions, the laptop does not have that issue with Edge or any other browser on her laptop.
Anyway I think Vivaldi is great, never crashes and never had any real security issues :) .
Side Note: I wonder how many Firefox users left once the official first Quantum build came out? I know I'm one .
Btw I did not like Brave, too basic for my needs.
Yeah Vivaldi is great. The only issue I have right now is that the Google Keep extension doesn't sign in for me, but that's less of an issue now that Vivaldi has it's own note making feature which syncs between devices.
Other than that, it's the best browser out there in my opinion. Also coming from a former Firefox user, though one which largely moved to Chrome several years ago.
Another minor update:
A minor update to the stable release of Vivaldi 3.4 has arrived!
Get the full story by visiting the Vivaldi blog (vivaldi.com/blog)
Changelog since Vivaldi 3.4 (2066.76)
  • [Address bar][Extensions] Focus not in address field when using new tab extension VB-73167
  • [Chromium] Upgraded to 86.0.4240.112
  • [Cookies] Logging into some sites in a private window does not work VB-72568
  • [Cookies] Blocking third party cookies without exception VB-73372
  • [Keyboard] Single key shortcuts leads to changing tab on some input fields VB-72174
  • [Menus] "Tools → Capture → Page to file" does not work VB-72863
  • [Menus][Settings] 'Restore to default' resets all menus not only the chosen menu VB-73132
  • [Menus][Tabs] Mute item shown even when already muted VB-73296
  • [Vivaldia game] Favicon is sometimes not displayed VB-73184
  • [macOS][Media] H.264 decoding/playback broken older macOS: further fix VB-71803
