Hi all,
So i've wanted to change the radio on my Vivaro (2010) for a while and I took the plunge this weekend.
I went for an Xtrons unit (https://xtrons.co.uk/opel-vauxhall-holden-android-12-quad-core-2gb-ram-32gb-rom-psf72vxa-b) which as far as I'm aware is mean to 'come with everything needed' so the correct wiring harness etc.
My problem is it's apparently not a quick unplug and plug in the new one job, the pins don't line up and looks like I either need another converter, or I need to get fancy and move the pins about.
Can anyone assist? I'm relatively good with things like this once I have the information, but I'm struggling to get the info at the moment
EDIT: If I can find a wiring diagram for the existing radio I might be alright.
