OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi all,
You can now jump in and immerse yourself at the deep end of VR with the now available to pre-order VIVE PRO FULL KIT. We should be able to ship these within 2 weeks, so you won't have to wait long!
HTC VIVE PRO Full Kit - HD VR Headset, Updated Controllers and 2.0 Base Stations Bundle @ £1,299.00 inc VAT
Bundle Includes: HTC VIVE PRO HD VR Headset, 2 x SteamVR Base Station 2.0, 2 x HTC VIVE Controller (2018), Supports Steam VR 2.0 Room-scale tracking up to 20'x20'
Only £1,299.00 inc VAT.
ORDER NOW
VIVE Pro delivers immersion unlike any other: true-to-life precise tracking, ultra-vibrant colors and uber-realistic sounds create a world that transports you to any scene in split seconds. With the highest quality display of any VR headset, VIVE Pro gives life to any realities.
Hi-Res Headset (HMD) + 3D Spatial Audio
Re-engineered and Optimized Ergonomics
Latest SteamVR Tracking System
Wireless Powered by Intel® WiGig *sold seperately
Enhanced Optics
SPOT EVERY DETAIL
See the difference with VIVE Pro. The all new screen panels dazzle the eye and sweep you away into your wildest imagination. Uncompromising, super-rich colors and details bring objects to life like never before.
2880 x 1600
615 PPI
37%
PPI Increase
78%
Pixel Increase
High-Res Soundstage
3D SPATIAL AUDIO
Hear every world as intended by its creator. The Hi-Res certified HMD and headphones are now integrated with 3D spatial sound to deliver for true-to-life immersive audio. The powerful amplifier is capable of driving high-impedance headphones - creating soundscapes that will change your world. The dual microphones allow for active noise cancellation as well as enabling Alert Mode and Conversation Mode - so you hear your surroundings while being immersed in any realities without the need of taking off the headset.
Hi-Res Audio Certification
Powerful Digital Amplifier
Dual Microphones -
Active Noise Cancellation Alert Mode and Conversation Mode
DESIGNED FOR COMFORT
VIVE Pro is engineered from top down for optimized ergonomics. Just place the headset on your face, slide the strap over your head–it’s done. The new chassis evenly distributes the weight of the device to achieve an optimal center of gravity - creating comfort in VR that is unlike any other.
Optimal Center of Gravity
Increased Point of Weight Support
24% Increase in Face Gasket Surface Area for Lowered Stress
Quick Adjustment Dial
SteamVR™ Base Station 2.0
ROOM-SCALE JUST GOT ROOMIER
Expand your horizons by adding additional base stations to track even larger interactive room-scale space.
Sub-Millimeter Precise Tracking
Large-Scale Tracked Areas
Ideal for Multiuser VR
VIVE PRO HMD includes
Headset
Headset cable (attached)
Face cushion (attached)
Cleaning cloth
Earphone hole cap (2)
Documentaion
Link box
Power adapter
DisplayPort™ cable
USB 3.0 cable
Mounting pad
Also Included:
VIVE PRO SPECS
Unprecedented presence with Hi-Res and 3D spatial audio
Stay immersed comfortably with higher display resolution, easy-to-use headset & cable design, and improved ergonomics
Chaperone technology
Free to move around wirelessly with VIVE Wireless Adapter*
*VIVE Wireless Adapter sold separately.
Headset Specs
Screen: Dual AMOLED 3.5" diagonal
Resolution: 1440 x 1600 pixels per eye (2880 x 1600 pixels combined)
Refresh rate: 90 Hz
Field of view: 110 degrees
Audio: Hi-Res certificate headset
Hi-Res certificate headphone (removable)
High impedance headphone support
Input: Integrated microphones
Connections: USB-C 3.0, DP 1.2, Bluetooth
Sensors: SteamVR Tracking, G-sensor, gyroscope, proximity, IPD sensor
Ergonomics: Eye relief with lens distance adjustment
Adjustable IPD
Adjustable headphone
Adjustable headstrap
ORDER NOW
Enhanced Optics
SPOT EVERY DETAIL
2880 x 1600
615 PPI
37%
PPI Increase
78%
Pixel Increase
High-Res Soundstage
3D SPATIAL AUDIO
Dual Microphones -
Headset
Cleaning cloth
Documentaion
Link box
Power adapter
DisplayPort™ cable
USB 3.0 cable
Mounting pad
Also Included:
VIVE PRO SPECS
Headset Specs
Refresh rate: 90 Hz
Adjustable IPD
