1920 LCD panels at 110 fov for £1,300
hahahahahahahahahahahahaha
What's its USP?
There has to be a manufacturing issue with OLED, I don't buy only sony are willing to use them at this point. It's seems VR is very stagnant at the minute.
What do you mean by stagnant?
Theres loads of VR moviesHopefully in the future more and more people get into VR, then we can have some VR movies![]()
Theres loads of VR movies![]()
Nothing revolutionary to get excited about. I am interested to see what Valve at up to though.
I'm just being impatient
I'd love to see a lightweight OLED headset, with high resolution able to stream wireless PCVR without encoding.
It will be Apple who do it I guess.
Are they the ones with the happy ending?Theres loads of VR movies![]()
I won't be happy until we have holodecks (with sex brothels)
No, the HTC specs say you can also connect to pc over wifi6, you can also remove the battery and connect via usb but it supports both wired and wirelessI'm a bit confused. Some videos on YouTube say you need to connect via USB to play PCVR games.. I look forward to some reviews though.
