Set up the VLANS on your L3 switch (3500s by any chance?), one for voice and one for data. Give them the .1 address for that VLAN. Make whichever ports on your L3 switch that will link to your L2 switches as tagged for the voice vlan, and untagged for data. Then set up the VLANS on your L2 switches and give them the .2 addresses. So for example, on your L3 switch:
ip routing
vlan 1
name "Data"
untagged 48 (or whichever port is feeding to your switch for that VLAN)
qos priority 0
ip address 192.168.1.1 255.255.255.0
vlan 101
name "Voice"
qos priority 4
ip address 192.168.101.1 255.255.255.0
tagged 48
voice
And then you would link port 48 to your L2 switch (say port 26 on there), and set up the config as follows:
no lacp 25-26 (these are the two uplink ports on a 24 port Procurve switch)
vlan 1
name "Data"
ip address 192.168.1.2 255.255.255.0
untagged 1-24
tagged 25-26
vlan 101
name "Voice"
ip address 192.168.101.2 255.255.255.0
tagged 1-26
primary-vlan 1
ip default-gateway 192.168.1.1
That should work. You should be able to route betweek the VLANS and split the data and voice traffic. You can expand on this further by setting up Trunking and having two GB links to each of your edge switches from your L3 switch to satisfy increased demand.
Hope that helps, let me know if you need anything else.
Hi again!
After having a play for a few days I'm still struggling to get the VLANs working the way they should. I have set up a Virtual server and several laptops for testing:
Here is what I want:
Server: 192.168.5.22 (runs DHCP, DNS, WINS) and has a secondary IP of 192.168.4.22 (DHCP scopes on both of those subnets .4.0/24 and .5.0/24)
Laptop 1: DATA laptop. Configured with a reserved IP of 192.168.5.51.
Laptop 2: DATA laptop. Configured with a reserved IP of 192.168.5.61
These 2 DATA laptops need to be able to see both the DATA subnet (.5.0/24) and the voice subnet (.4.0/24)
Laptop 3: VOICE laptop. Configured with a reserved IP of 192.168.4.51
Laptop 4: VOICE laptop. Configured with a reserved IP of 192.168.4.61
These 2 VOICE laptops (representing VoIP phones in this test) need to be able to see the .4.0/24 subnet only. However There will be some phones for example that will have PC's attached to them. Those PC's will need to communicate with the other data servers on .5.0/24 subnet.
There will be 2 VoIP servers configured with .4.10 and .4.11 addresses. These 2 servers need to see both voice and data subnets.
Now onto the switches!
The 2 Procurve switches:
1st one is the 2900-48G. This will be the main L3 switch in the network. The current config is as follows:
General settings:
ip default gateway 192.168.5.22 (for testing)
ip routing enabled
interface 47 lacp passive
interface 48 lacp passive
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-A4
qos Priority 1
ip helper address 192.168.5.22
ip address 192.168.5.1 255.255.255.0
jumbo
exit
vlan 2
name "Voicevlan"
qos priority 4
ip helper address 192.168.4.22
ip address 192.168.4.1 255.255.255.0
tagged 25,47
voice
exit
2nd Procurve switch (2900-24G) is in this example representing a DLINK 24 port PoE switch. It is configured as follows:
General settings:
ip default gateway 192.168.5.1 (main switch)
ip routing enabled
interface 23 lacp passive
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-2,4,6-24, A1-A4
qos Priority 1
ip address 192.168.5.2 255.255.255.0
jumbo
exit
vlan 2
name "Voicevlan"
qos priority 4
ip address 192.168.4.2 255.255.255.0
untagged 3,5
tagged 23
voice
exit
Ok.
The 2 "voice" PC's are in ports 3 and 5 of the 24 port (2nd) switch. They need to be able to communicate only with the servers and other phones that will be on the .4.0/24 subnet (255 is miles more addresses for that subnet than I will ever conceivably need).
The 2 "data" pc's are in port 1 of the 2nd switch, and port 1 of the main switch (48port 2900). They need to be able to communicate with both the .4.0/24 subnet and the .5.0/24 subnet and correctly pick up a .5.0/24 DHCP assignment from the server 192.168.5.22.
Problems:
I think where I am struggling is correctly identifying what ports need to be "tagged or untagged" for the corresponding VLAN. I thought I had it cracked yesterday when everything seemed to work OK, but since then something has happened by itself in that the "DATA" PC's have not been able to see anything else.
Can someone give us some pointers about what needs to change in the current config for it all to work please? I suspect the ageing network cards in my test laptop may not support 802.1q so I may need to dump the qos priority (maybe thats the issue?) Either way I'm reading hundreds of pages and still not correctly getting the whole tagged/untagged principles yet. I'll re-read again today!
Thanks in advance.
CK
