VLC Player - Fix Window Size
7 Feb 2010
In case anyone else hates the way VLC Player auto re-sizes the window, there is a setting buried deep that allows you to keep it one size.
Untick the 'Resize interface to the native video size' option in:
Tools -> Preferences (Show settings: All) -> Interface -> Main interfaces -> Qt
It's even easier than that in the new versions (1.0.0+)!
Tools Menu -> Preferences -> Interface (Make sure you're still in Simple mode rather than All) and uncheck 'Resize interface to video size'
You're welcome lads. I figured there'd be a few who'd appreciate this.
One of the lovely things with having a wide screen is the excess space to the side of your windows. So I like to play vids while I browse and this tweak keeps them running in a playlist without having to adjust. Now if I could set the default resolution it would be golden.
Update to newest version, un-check resize, un-check YUV>RGB, enable GPU acceleration. Profit?
Just tried these, let's see if I notice any difference.
