Tells you which row of your array (B7:B9) the value A2 exists in.
Code:
=INDEX($A$7:$A$9,MATCH(A2,$B$7:$B$9,0))
Reads the row of your description array (A7:A9) where the match was
BTW you should use $A$6:$B:$9 for the VLOOKUP range - if you don't put the dollar in then when you drag the formula down excel auto-increments the numbers. Line 4 is doing a lookup from A8:B11!
