Hello.
A few months back my Virgin Media SH2ac died and good old VM replaced it with a SH3.
Firstly what on earth have they done to the admin console? Its slow, awful and a poor replacement for my
SH2ac.
I have the SH3 connected by a cat 6a to my switch and out of that another cat6a to my PC.
I do get good upload and download speeds on the PC. Can not fault that.
However I get very poor wireless speeds. Even standing in the room with the router, I get speeds of 70mbs on my phones and tablets.
I ran a diagnostic from the router's own tool and I get some concerning reports.
Plugged in to the router is the switch, my blu ray player and my wife's laptop.
I would expect the ports with the router and laptop to be running at 1gb.
I know they did when I had the SH2
Wifi signal reports are terrible, I would expect -50dBm or better.
Any advice?
Diagnostic Results...
WiFi signal strength of Google-Home is -82dBm.
WiFi signal strength of Big IPAD is -89dBm.
WiFi signal strength of Mobile Phone is -86dBm.
WiFi signal strength of Mini iPad is -65dBm.
Wireless primary network is Enabled on 2.4GHz.
Wireless primary network is Enabled on 5GHz.
Wireless guest network is Enabled on 2.4GHz.
Wireless guest network is Enabled on 5GHz.
Internet connection is good.
Telephone line 2 is disabled
Telephone line 1 is disabled
Wired client on port 3 is running at 100 Mbps.
Device connected on port 3 is running at a lower speed of 100 Mbps and is not utilizing the full available speed.
Wired client on port 1 is running at 100 Mbps.
Device connected on port 1 is running at a lower speed of 100 Mbps and is not utilizing the full available speed.
Wired client on port 2 is running at 10 Mbps.
Device connected on port 2 is running at a lower speed of 10 Mbps and is not utilizing the full available speed.
SH2ac.
Any advice?
