VMware CLI help with sed command
Man of Honour
20 Sep 2006
I'm trying to script the cloning of VMs using ESXI 5.5
I don't have vCenter so I used the script at the bottom of this page:
http://nchrissos.wordpress.com/2013...ut-vcenter-in-esxi-5-1-free-edition/#comments
At first it wouldn't work so I thought I'd made a mistake, so I created folders exactly like his. I get the same result.
Clone: 100% done.
sed: unsupported command ▒
What is it about the sed command it doesn't like?
Looks like the sed command didn't like " so I swapped it with ' and now the VM gets created. Great.
But it's call $1 as there is a reference to this in the vmx. I suspect sed isn't understanding the $1 variable.
I'll continue testing.
This is what's in the script now:
Code:
#!/bin/sh
mkdir /vmfs/volumes/SSD\ RAID5/$1
vmkfstools -i /vmfs/volumes/SSD\ RAID5/Template2012/Template2012.vmdk /vmfs/volumes/SSD\ RAID5/$1/$1.vmdk -d thin
cp /vmfs/volumes/SSD\ RAID5/Template2012/Template2012.vmx /vmfs/volumes/SSD\ RAID5/$1/$1.vmx
sed -ie 's/Template2012/$1/g' /vmfs/volumes/SSD\ RAID5/$1/$1.vmx
vim-cmd solo/registervm /vmfs/volumes/SSD\ RAID5/$1/$1.vmx
Something like this:
New-VM -Name "NewVMName" -VM "VMtoCloneFrom" -VMHost "ESXiHostname"
Not as far as I can tell... I just did a quick Google, and it will connect to a standalone host. Obviously not all the commandlets are applicable, but the example I gave should work... I've only ever used it with vCenter, so do tell us how you get along if you do test it.
