VMWare help
15 Feb 2008
Hi,
i am looking at setting up a windows home server and wanted to set up a test server in vmware but get the following errors up on loading the iso file.
Can someone please explain how to sort this, i can load other OS in vmware just not server 2011 ... the rig i am using is in my sig.
well pretty much what is says. Check your bios and enable VT and disable trusted execution.
If it's the rig in your sig it should have that feature
Your other operating systems probably aren't 64bit so it isn't an issue
thanks mate, forgot to disable trusted execution :o
