VMWare - Increase in Drive space
30 Dec 2004
Stoke-on-Trent
Morning,
Just a quick question I have Linux installed in VMWare and running out of space on *** virtual drive, is it possible to enlarge the space give to the OS without corrupting it? e.g. just change summat in the settings.
Ta
I did a quick search on the vmware forums and found a guy saying there is a cmd line utility called "vmware-vdiskmanager.exe" which (with a default install) will be in the "C:\Program Files\VMware\VMware Server" folder. If you click here you'll see the thread I found.
One guy's done a GUI for the cmd line program, you can find that right here.
Obviously, I would recommend you make a copy of the virtual disk files before trying it ;)
