VMWare Question/Issue
28 Jun 2005
Hi. Got myself into a bit of a mess. I've got a W2K3 image that I've been using, shutting down, taking a snapshot off, and then restarting to add more software. I've got a stage where I want to make a full clone with everything installed and running. I had the image running and took a snapshot of the machine up and running as I wanted to quickly test something, then accidentally logged the server off that was running the image. No I seemed to be screwed. I can't clone the online copy, as it's an online copy. If I try to clone one of the previous offline snapshots it tells me I can't as 'one of the disks in this virtual machine is already in use by a virtual machine or snapshot'. I can't delete the online snapshot as it says the virtual machine is a template. If I revert to an earlier snapshot and try to clone it I get the same 'in use' message. Any ideas?
Can you install vmware onto another similar machine and restore a snapshot onto it?
