VMWare question
23 Oct 2002
Colchester
What is the easiest way to setup a second virtual machine without going through the install and update bit. Is it possible to copy an existing machine?
I tried to just copy/paste but couldn't get the network/internet access to work on the copy.
Cheers
Steevo
Yeah you should be able to just copy the VM.
Does the 2nd VM work ok if it's the only one running?
No it didn't.
Perhaps I'll give it another go at the weekend.
Got the old VM running along side a winsmp client at the moment. cpu at 333x8 and looking like 3300 ppd. :D
Cheers
Steevo
If your using the Workstation versions (4.x or 5.x or above), try using the snapshot function instead of copying.
I have copied VM's from one machine to another before, didn't have any trouble, but I use the workstation version not the free viewer.
