vmware server problem
1 Jun 2005
Kent
I was attempting to try and learn a bit about virtual machines and more importantly, opensolaris. The problem is, I finaly managed to install vmware server on ubuntu 9.10 (I had to use a script someone developed to get it to work on 9.10), managed to log in to the web access management thing and create a VM ready to put opensolaris on, when for some reason the web management process crashed. I tried to restart it, and the terminal output seems to haev suggested it worked, but i can no longer access it.
So, i decided I would uninstall vmware server and take someone elses advice and try virtual box, the problem is, when I try run the vmware uninstall script, it gives me an error saying i need to power down each VM first. How do I go about doing this if i can not get the web management working?
These problems are most likely caused by my inexperience with linux, but im trying to just dive in to the subject and learn by doing, which may mean making stupid newbie mistakes. Without a book to hand on the subject im clueless as to how to sort this out.
Well it seems that even though manualy restarting the web management access didn't work, restarting my whole system seems to have got it to work (I guess vmware auto runs on startup).
So the question is now that I have vmware server working again, should I stick with it to learn about opensolaris, or uninstall and get virtualbox instead?
You can just kill the running vmware processes. However I might suggest trying vmware server 1.9, we have found server 2.x not very reliable..
Yeah ps -ef|grep -i vmware and kill all the processes you see and then you should be able to remove vmserver.
Virtualbox should be much better at handling OpenSolaris as it can deal with Solaris 10 very well (and is a SUN production to).
Good luck
