- 18 Oct 2002
We're trying to improve our storage connections in VMWare.
We've had a consultant in who's given us a design to implement.
We've got 5 ESXi 5.5 hosts, with 4 10GbE ports each.
The advice is to split our traffic into 4 VLANs on different subnets - NFS, iSCSI_A, iSCSI_B, and VMotion. Seems sensible to me, segregates the traffic and allows MPIO for iSCSI.
The bit I'm struggling with is the physical uplink port config and the standby links. The design states:
Port 1 - NFS Active, vMotion Standby
Port 2 - iSCSI_A
Port 3 - iSCSI_B
Port 4 - VMotion Active, NFS Standby
So I need 4 vmk's and 4 vSwitches, but I need 2 of the physical uplinks to be present on 2 vSwitches so I can set up the standby links. I can't seem to configure this using standard vSwitches because once an uplink is assigned to a vSwitch it disappears from the list for new vSwitches. If I put 1 and 4 on the same vSwitch with the NFS and vMotion vmk's, I get a team which will work but doesn't give the true traffic separation we are seeking.
It appears to create this config we would need to use distributed vSwitches. One of my colleagues is against this because our hosts are not identical so the vmnics have different numbers. From what I've seen this is not a problem as you assign physical ports to the dvuplinks for each host?
Port 2 - iSCSI_A
Port 3 - iSCSI_B
