Hi chaps,
I'm trying to spec up an old machine that I have to more comfortably run a lab at home (and do a myriad of other daily tasks including video editing / photography work) and I'm just wondering if people might be able to point me in the right direction as I've been out of the hardware loop for a while.
I'm using Vmware workstation 7 at the moment to run a couple of VM's for exam work - 2 domain controllers and a client for example. I also use workstation for various bits of linux learning andto simulate a vsphere / vcentre environment.
So really its a learning tool / exam taking machine. It started off life as a gaming rig but has developed from there.
Having a number of hard disks on different channels was my first port of call.
At the moment I have a RAID 1 320gb stripe for my OS (win7) and a seperate 80GB unit for one set of VM's. I also have another 500gb unit with some more VM's on.
I/O contention is a killer on workstation I've found. (Wouldn't we all love home SAN's).
I'm also finding the 4GB ceiling of my socket 939 board and the lowly 5600+ amd dual core to be an issue.
I'm guessing the best option for me is to find a new rig with 8GB of ram and a quad core processer.
I've been having a good read around the boards the last few weeks and the toss up seems to be between the i5 and some variation of a phenom / lesser quad on the AMD side.
I must say that AMD's price point particularly with regards memory makes it very attractive.
Could anyone point me in the right direction given my use and current rig ?
5600+ amd
4GB DDR2 PC6400 memory
320GB RAID 1 Stripe sata
80gb sata drive
500gb sata drive
Socket 939 board MSI K9N neo
8800GTS graphics card
600watt psu
Many thanks in advance.
5600+ amd
80gb sata drive
500gb sata drive
600watt psu
