Vmware Workstation.
26 Jul 2007
Not sure if this is the right board, but ill post anyway.
Probably a simple Question, but basicaly what i want to do is have my local Machine (windows 7) with 2 network cards installed on two different networks with my VMWare machine (windows 7) using one for its network and the local machine using the other.
What i want to know is, is it simple enough and is it done by using the VMware virtual network editor and assigning VMnet2 for example as the NIC i want to use and setting that as the choice of network connection in the VMware network setup.
Thanks
I think it's: Edit > Virtual Network Editor
Then just pick the the Virtual NIC, then bridge it to whatever physical NIC you want it to.
I think :P
