VNC onto a Wyse terminal
6 May 2009
Is it possible to VNC onto a Wyse terminal? I am trying to find out the CE build number through Control panel - System
I have had replies to a thread on freewysemonkeys.com saying -
You VNC in teh terminal and then open Control Panel -System to see the CE build number.
Compare that with the latest available from wyse.com. Based on that you should consider a firmware upgrade on the affected units.
I have then asked how i find the IP address of the Wyse box and had this reply -
Control Panel-System or check your DHCP server for the MAC address.
How do I check my DHCP server for the MAC address? Even if I did find the MAC address surely i couldnt VNC onto an ICA session as VNC wouldnt be running anyway?
Thanks
