VNC that works on PDA with WM5
27 Dec 2002
Beyond the Ultraworld...
Is there a VNC app that will let me control a PC from my PDA that is running WM5?
If so, would it be able to work if my PDA is using GPRS and not WIFI?
You can use remote desktop from windows mobile 5 IIRC.
You'll struggle to use it over GPRS though - pretty sure the amount of data being transferred would be too large.
Mocha VNC is what I use, even on my 640x480 screen it's a bitch to use due to size but it is doable :)
I haven't tried it on a non-3G connection but again, it should be doable.. just don't expect that good a refresh rate.
Thanks for the replies :)
All I need to do is make sure that the the VNC connection can be established so I not too bothered about the refresh rate.
Muchos Gracias :)
