VOB editor?
31 Jul 2004
Surrey
I've connected up a camcorder to my hdd/dvd recorder, the best way I've found to do this is to dub from the extrnal source to the hdd which means I have as much space as I need to store the image.
Then I can dub it onto dvd from the hdd, problem is there are no chaptering options and obviously there's a load of guff I'd like to get rid of. My pc sees the file in .vob and its always name "sony dvd recorder blah blah" so I'd like to be able to name the disc etc too.
Anyone know of an easy way of doing this? I'm happy to rip the dvd onto my pc, got plenty of hdd space there, it would be great if I could have some sort of visible way of cropping and chaptering.
Cheers in advance.
cool, I'll check them out..
any more?? this has to be moron proof, for some reason I just can't bring myself to learn about AV.. any whiff of a manual and I'm off like a shot :D
Theres a couple I use , VCDcutterXP will view and edit .VOB files and another great piece of software is VideoRedo Plus , this also does the same but easier.
