Hello all, just here for a bit of advice, HiS eventually came back to me about my faulty 7950 and have deemed it as warranty void, not going to lie - pretty miffed about it, wont be buying any HiS branded hardware going foward.
Anyways on to my query - any advice on what I should do with my pc, I game at 2560x1440 and had* been running crossfire 7950's (boost), with the faulty gpu I'm down to one and would like to see what you think my best option is to go
1: - buy a second hand 7950, pick it up cheap (ensuring it hasn't been used for mining as I know these are flooding the market)
2: buy a new 280 (as they are sort of 7950's)
3:Hold out for a bit and see if there are any single gpus down the pipeline expected to come out that will easily handle 2560x1440 at high-max settigs
Here's the link to previous thread (which has link to previous to thread with pictures too - thread-ception
) - http://forums.overclockers.co.uk/showthread.php?t=18590428
4:- any suggestings from the gen-pop ;P
Thanks for taking time to read and I appreciate any suggestions
) - http://forums.overclockers.co.uk/showthread.php?t=185904284:- any suggestings from the gen-pop ;P
