VOIP Options
24 Dec 2002
Southampton
Retiring to a house in Nicosia. Broadband and a 4m+ sat dish will make life easier for two English Speakers.
VOIP phones will parallel the land line for UK phone calls. I have a couple of Sipgate accounts I have used before in Germany - German telecoms are eccentric, so I was using the router provided by D Telecom ans a pair of German DECTs.
I have a couple of Wireless Routers (and a cable job) - that's what happens when you are always moving!
The Sipgate accounts are still active, so I will take with me a pair of Siemens dual standard DECTs
Sipgate's best offer seems to be
Gigaset A580 IP
and
A58H - Additional handset
Is it worth going for a more expensive model? Can anyone recommend other suppliers?
On retirement, I will need to purchase a mobile phone (shock - horror). A`pay as you go Cypriot account will be all I need, but if I get a suitable handset I can used that too for VOIP. I expect if you are cheeky you can sit down in coffee shop or tavern with free internet and phone home!
This seems the cheapest
sipgate.co.uk - free phone service over your broadband link - voice over ip provider
any comments?
Will the Mobile/VOIP phone work with the home DECTs without interference, becuase I guess they will be independently loging on via the router?
Although another part of the hi tech strategy includes Squeezeboxes for Internet Radio, and if I choose a more expensive smartphone it would act as a Squeezebox controller and a portable music player.
Any more comments?
The cost of telephony will be insignificant compared to the cost of a 4.3 metre sat dish, but every little helps.
The wisdom of any guru would be welcome, and if someone has knowledge of Cyprus, even better.
