VoIP Trunking
1 Aug 2003
Can anyone recommend any good VoIP trunk providers for the UK? I've only ever used them in the US
Edit: Or SIP trunk providers I should have said
What exactly are you after, how many numbers, how many concurrent channels, what do you plan to use it on etc.
We currently provide about 1000 trunks to different companies.
I'm running an Asterisk server, it would only need to handle one number (possibly two if we port over the fax line) and would most likely need to handle around four concurrent calls at any one time.
