So doesn anyone on here know of or have a guide/pics of a volt mod for the gtx275. i have seen one guide floating around about soldering a 100k POT on the voltage sensor for the card tricking the card into sending more power to the core. i would also like to know if anyone knows of how to overvolt the ram on the card as 1200mhz will quickly null my core clocks
Cooling should not be a issue, i have adapted a cpu water block to the gpu core and it has its own dedicated triple 120 rad cooling it with a 450GPH pump. the ram,mosfets,chipset are all air coold with the stock heatsink being blown over by a 190cfm 120(on controller).
The twinfrozr cards heatsinks are acutally made up into 2 parts. the main heatpipe assy with the 2 fans, and then and heat spreader with fins and fingers for everything els.
